It is currently April 25th, 2024, 12:16 am
 Post subject: 15 inch woofer for OB
PostPosted: August 31st, 2020, 6:25 pm
What parameters do I look for for a two way OB system with two 15 inch woofer per side
PostPosted: August 31st, 2020, 8:31 pm
Paul,
I looked into this when I was considering an open baffle woofer for my Bassillas. Normally you look for a woofer with a Qt from 0.5 to 1.0. I think the Goldwood 18" woofers Roscoe used on his baffles a while back were at the upper end of this range. These have a response rise at the resonance frequency that helps compensate for the 6dB/octave baffle rolloff and extend the bass response. However with an active system, or passively if you are using a very efficient 15in driver (or two) you can do this with a bass lift filter network and a more highly damped driver. It will require more amplifier power though.
This is just a broad brush. You can find some good information from designs by Olsher, Pass, Linkwitz, and others on open baffles (or H-bins, slot loaded, all variants that extend the baffle size by folding).
PostPosted: August 31st, 2020, 8:46 pm
You should find the following links useful.
https://www.diyaudio.com/forums/multi-way/110583-fast-fun-inexpensive-ob-project.html
https://www.diyaudio.com/forums/multi-way/355643-eminence-alpha-ob-question-4.html
Users browsing this forum: No registered users and 57 guests
