| Analog multi-meter http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=1588 |
Page 1 of 1 |
| Author: | mix4fix [ March 16th, 2020, 12:53 am ] |
| Post subject: | Analog multi-meter |
Tom gave me an old analog multi-meter. One thing I noticed was the lead connections look like banana plugs. I thought the leads on modern DMM (Fluke) was standard for every kind? Put batteries in it (9V and AA) and tested it on ohms and VAC. |
| Author: | tomp [ March 16th, 2020, 9:30 am ] |
| Post subject: | Re: Analog multi-meter |
That meter is probably 30 years old so who knows what was used back then. I also have some older test equipment that has AC input sockets that are not used anymore. If the cords fail I will have to replace the input sockets with IEC sockets. Time marches on. |
| Author: | SoundMods [ March 16th, 2020, 9:33 am ] |
tomp wrote: That meter is probably 30 years old so who knows what was used back then. I also have some older test equipment that has AC input sockets that are not used anymore. If the cords fail I will have to replace the input sockets with IEC sockets. Time marches on. PLUS -- it was FREE!!! In the realm of DIY you adapt -- you create -- you make it happen. |
| Author: | David McGown [ March 16th, 2020, 10:21 am ] |
A 30 year old multimeter is before any safety standards/considerations to guard the male jack to prevent shock when inserting or removing leads. It is pretty typical for older multimeters and other test equipment to have a simple banana plugs or 3-way binding posts with banana plug leads. Should be easy to find a pair of leads on Amazon. David |
| Author: | tomp [ March 16th, 2020, 12:57 pm ] |
The original leads were with it. |
| Author: | SoundMods [ March 16th, 2020, 1:32 pm ] |
tomp wrote: The original leads were with it. I expect that the multi-meter had pin jacks. Leads for those aren't easy to find but there is at least one listing on eBay. https://www.ebay.com/itm/HERMAN-H-SMITH ... SwsvZdMySW |
| Author: | Pelliott321 [ March 16th, 2020, 3:01 pm ] |
those are no good they are not free |
| Author: | SoundMods [ March 16th, 2020, 3:04 pm ] |
Pelliott321 wrote: those are no good they are not free OH! My bad! |
| Author: | Cogito [ March 17th, 2020, 8:53 am ] |
Pelliott321 wrote: those are no good they are not free Candidate for the "Best Post of 2020"! |
