| Daphile software http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=1474 |
Page 1 of 1 |
| Author: | mix4fix [ October 31st, 2019, 11:41 am ] |
| Post subject: | Daphile software |
What causes Daphile to change network addresses? What's an easy way to find out the new address? |
| Author: | Roscoe Primrose [ October 31st, 2019, 11:56 am ] |
| Post subject: | Re: Daphile software |
DHCP. Hook up a monitor and the IP address will be on the screen. Yuo may be able to find it on your network at http://daphile or http://daphile.local Once you get connected, go into the network settings and set a static address. Roscoe |
| Author: | mix4fix [ October 31st, 2019, 12:14 pm ] |
It was 192.168.1.101 It changed to 192.168.1.104 Now when I go to 192.168.1.104, it doesn't load. I just clicked your link, and it came up. Is that the permanent link? |
| Author: | Roscoe Primrose [ October 31st, 2019, 12:31 pm ] |
That link should work even if the IP address changes.... Roscoe |
| Author: | Pelliott321 [ October 31st, 2019, 1:18 pm ] |
Are they working to get Daphile work on new RSPi 4 |
| Author: | Roscoe Primrose [ October 31st, 2019, 1:22 pm ] |
Last I heard there were no plans for an RPi port |
