| DAC output stage http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=1450 |
Page 1 of 1 |
| Author: | Cogito [ September 18th, 2019, 9:48 pm ] |
| Post subject: | DAC output stage |
In 2001 with help of folks in another forum, I replaced the opamp with a pair of nickel 1:2 75ohm transformers. The improvement was huge. I still have the transformers and want put them to use. DIYINHK is selling a dual mono Ess9038 based DAC. The best feature of the DAC is, you easily hookup a custom IV and LPF stages easily. Going to order the DAC to play around . Any ideas for an “audiophile” grade LPF and tube IV stage. We can collaborate if interested. https://www.diyinhk.com/shop/audio-kits/148-dual-mono-es9038q2m-es9018k2m-xmos-dsd-dxd-768khz-usb-audio-dac-with-bit-perfect-volume-control.html |
| Author: | Pelliott321 [ September 19th, 2019, 6:42 am ] |
| Post subject: | Re: DAC output stage |
Confused If you are going to use the transformers why do you need the tube I/V |
| Author: | Cogito [ September 19th, 2019, 8:13 am ] |
Pelliott321 wrote: Confused If you are going to use the transformers why do you need the tube I/V If the IV and LPF stages are modularized, transformer or tube IV stages can be hooked up easily. Andrea Ciuffoli published the schematic of his tube IV stage. |
