It is currently November 27th, 2026, 8:09 am
 Post subject: DAC output stage
PostPosted: September 18th, 2019, 9:48 pm
In 2001 with help of folks in another forum, I replaced the opamp with a pair of nickel 1:2 75ohm transformers. The improvement was huge. I still have the transformers and want put them to use.
DIYINHK is selling a dual mono Ess9038 based DAC. The best feature of the DAC is, you easily hookup a custom IV and LPF stages easily.
Going to order the DAC to play around . Any ideas for an “audiophile” grade LPF and tube IV stage. We can collaborate if interested.
https://www.diyinhk.com/shop/audio-kits/148-dual-mono-es9038q2m-es9018k2m-xmos-dsd-dxd-768khz-usb-audio-dac-with-bit-perfect-volume-control.html
 Post subject: Re: DAC output stage
PostPosted: September 19th, 2019, 6:42 am
Confused
If you are going to use the transformers why do you need the tube I/V
PostPosted: September 19th, 2019, 8:13 am
Confused
If the IV and LPF stages are modularized, transformer or tube IV stages can be hooked up easily.
Andrea Ciuffoli published the schematic of his tube IV stage.
