http://dcaudiodiy.com/phpBB3/
Balanced to unbalanced converter
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=1171
Page 1 of 1
Author:  tomp [ March 24th, 2018, 8:49 pm ]
Post subject:  Balanced to unbalanced converter
At the DC HiFi Group meeting today, interest was expressed in the balanced to unbalanced converter I built as a project which became an audioXpress article. Unfortunately the two issues of the magazine covering the project are each larger than the 2 MB limit so I cannot load them. Instead, I'm including the schematic and two data sheets on the active devices used. The sheets not only contain info on the ICs but also great info on balanced circuits. They are both still available.
http://www.thatcorp.com/datashts/THAT_1 ... asheet.pdf
Balanced to unbalanced schematic 2.pdf [40.43 KiB]
Downloaded 1326 times
Author:  tomp [ March 25th, 2018, 11:09 am ]
Post subject:  Re: Balanced to unbalanced converter
I broke the article down to bite sized pieces. Here is the first issue:
Balanced_unbalanced #1a.pdf [539.82 KiB]
Downloaded 1425 times
Balanced_unbalanced #1b.pdf [755.36 KiB]
Downloaded 1335 times
Balanced_unbalanced #1c.pdf [204.26 KiB]
Downloaded 1493 times
Author:  tomp [ March 25th, 2018, 11:11 am ]
Here are the last three of the second issue.
Balanced_unbalanced #2b.pdf [338.25 KiB]
Downloaded 1450 times
Balanced_unbalanced #2c.pdf [563.06 KiB]
Downloaded 1436 times
Balanced_unbalanced #2d.pdf [498.58 KiB]
Downloaded 1393 times
Author:  tomp [ March 25th, 2018, 11:12 am ]
Here is the first of the second issue. Sorry I got this one inserted backwards.
Balanced_unbalanced #2a.pdf [523.22 KiB]
Downloaded 1423 times
https://www.phpbb.com/
