It is currently April 20th, 2024, 9:42 am
PostPosted: March 24th, 2018, 8:49 pm
At the DC HiFi Group meeting today, interest was expressed in the balanced to unbalanced converter I built as a project which became an audioXpress article. Unfortunately the two issues of the magazine covering the project are each larger than the 2 MB limit so I cannot load them. Instead, I'm including the schematic and two data sheets on the active devices used. The sheets not only contain info on the ICs but also great info on balanced circuits. They are both still available.
http://www.thatcorp.com/datashts/THAT_1 ... asheet.pdf
Balanced to unbalanced schematic 2.pdf [40.43 KiB]
Downloaded 652 times
PostPosted: March 25th, 2018, 11:09 am
I broke the article down to bite sized pieces. Here is the first issue:
Balanced_unbalanced #1a.pdf [539.82 KiB]
Downloaded 700 times
Balanced_unbalanced #1b.pdf [755.36 KiB]
Downloaded 655 times
Balanced_unbalanced #1c.pdf [204.26 KiB]
Downloaded 711 times
PostPosted: March 25th, 2018, 11:11 am
Here are the last three of the second issue.
Balanced_unbalanced #2b.pdf [338.25 KiB]
Downloaded 678 times
Balanced_unbalanced #2c.pdf [563.06 KiB]
Downloaded 667 times
Balanced_unbalanced #2d.pdf [498.58 KiB]
Downloaded 619 times
PostPosted: March 25th, 2018, 11:12 am
Here is the first of the second issue. Sorry I got this one inserted backwards.
Balanced_unbalanced #2a.pdf [523.22 KiB]
