Paul,
I am not too hung up on the Altec Cabinet anymore. Since you were here last time, I made a couple of changes to the compression driver which yielded excellent results.
Altec compression drivers have a bug screen, a brass mesh, within a quarter of an inch from the phase plug. Since the Altec gear is originally designed for theater use, the bug screen is needed to keep the bugs from crawling into the compression drive. I decided to remove it completely. Unfortunately, my horn and CD is inside the sealed enclosure, so I tried the 511s without the bug screen sitting on top of the cabinet. Liked liked the effect very much. Next, taking Walt's suggestion to the extreme, removed the dust cap on the compression drive. Eliminating the diaphragm resonances by removing sealed dust cap is a revelation. I also loved the effect of raising the horn and tilting it down towards the ear on the soundstage, so decided to leave them that way permanently. Need to build a stand for the 511Bs and an acoustic baffle behind the compression driver.
Unlike present day full range speakers which stand out on their own, Altec made home and studio monitors less than 30" tall overall. Their idea is to make Altec speakers part of home furniture/decor. Downside is, cabinets are smaller and horn is far below the ear level.
I am going to try damping the cabinets and stiffening the back wall like Walt did first and they go for building a bigger cabinet just for the woofer of around 12-14cft. My problem, I dont have any woodworking experience or woodworking gear.
