It is currently January 17th, 2026, 12:15 am
PostPosted: January 15th, 2026, 6:17 pm
Check this out.
https://antiqueradio.org/philc08.htm
PostPosted: January 15th, 2026, 7:00 pm
Also you might want to look at this for info:
Fortunately, the Philco Model 60 does have a power transformer.
https://philcoradio.com/library/index.p ... -model-60/
David M.
PostPosted: January 16th, 2026, 9:47 am
dberning wrote:
Unfortunately the chassis is long gone. Dad only had the case, and he put a Bose bluetooth speaker behind it.
I have looked but chassis (sic) are hard to come by. Would essentially need to buy an entire new radio and transfer everything over to it.
So with that all said - my options as I see them
I could buy a new tube amp and modify the case to utilize it. For example this one that PE sells. https://www.parts-express.com/Dayton-Au ... quantity=1
I could buy this and take the faceplate off, rear mount it and make the cutouts so the VU gauges showed. If I did that and figured out some older knobs to use instead of the ones it has, that could give me a period correct-esque appearance, and the older sound I would like. While it doesn't have an fm tuner- I could us tunedin on my phone and listen to any radio station technically.
Other option I thought of is a retro stereo. Would need a 12V power supply which would not be hard to do and all fit in the case easily. Again it is modifying the face but I am ok with that. Spirit of my Dad having the case is preserved. Thinking something like this https://www.retromanufacturing.com/coll ... 6990593180
Both options allow using the original case and give enough power to drive the sprites for sure. Honestly I think I could get away with the 20watt tube amp from PE for what I would be doing.
Appreciate everyone's assitance and input. Been a rough week with Dad passing and I am wanting to use this the way I know he wanted to, but did not have the skills for. Know there is a way to make it work without going crazy.
PostPosted: January 16th, 2026, 11:53 pm
Very sorry to hear about your father's passing. I'm sure it's been a very difficult week for you and your family. Really sweet idea to build this radio project as a reminder of him.
